just a lil thing I noticed, don't pump the accelerator pedal, its a efi car not a carbi car, turn key on to ignition reds and let fuel pump prime up, you will hear whirring sound.. then turn key to start. Pumping will cause issues with ecu and sensors/codes.
I will get out there and check all fuses and relays on the weekend. I will also chuck some fuel in it. Really hoping this issue will just go. But I won't hold my breath hahajust a lil thing I noticed, don't pump the accelerator pedal, its a efi car not a carbi car, turn key on to ignition reds and let fuel pump prime up, you will hear whirring sound.. then turn key to start. Pumping will cause issues with ecu and sensors/codes.
Just a lil hint, also you never know, how is the fuel pump/pressure ??? also put fuel in car as I see your on reserve, maybe pump has **** from bottom of tank ???
Another lil hint check all fuses/relays as the bcm will cut pump/fuel of if any body fuse like central locking is blown with cause immobilisor to stop start ??
The Throttle Position (TP) sensor is attached to the throttle body, and is internally rotated by the throttle body shaft. It is a potentiometer with one end connected to 5 volts from the PCM and the other to PCM earth. A third wire is connected to the PCM, allowing it to measure the variable output voltage from the TP sensor.
As the throttle valve angle is changed (accelerator pedal moved), the TP Sensor output voltage also changes in proportion. At a closed throttle position, the output voltage is usually below 1.0 volt. As the throttle valve opens, the output increases so that, at wide-open throttle, the output should be above 4.0 volts. By monitoring the output voltage from the TP sensor, the PCM can determine fuel needs based on throttle opening (driver demand).
A broken or loose TP Sensor, or one that has an unstable output, can cause intermittent bursts of fuel because the PCM thinks the throttle is moving. Results could include engine surge or poor idle quality. If the PCM interprets a high voltage when engine RPM is less than 400, hard starting could be the result (clear-flood mode).
A problem in any of the TP sensor circuits will set either a DTC P0122 or DTC P0123 after the engine is started. Once a Diagnostic Trouble Code is set, the PCM will use an artificial default value for TP sensor based on engine RPM to enable the vehicle to be driven, although performance could be less than normal. The TP sensor is not adjustable. The PCM uses the reading at idle as "0% throttle," so no adjustment is necessary.
???just a lil thing I noticed, don't pump the accelerator pedal, its a efi car not a carbi car, turn key on to ignition reds and let fuel pump prime up, you will hear whirring sound.. then turn key to start. Pumping will cause issues with ecu and sensors/codes.
