CHECK ENGINE" Warning Illumination and esp off, 08 SS
Big Wazza
VE SS V8
Hi, I was going for a drive today and stop and turned off my car. When I turn the car on the Check Engine warning light came on with the ESP Off sign and it was running abit ruff, by the time I got home it was running normal again. Every time I start the car the check engine comes on, i've done 144500km, Can any one help, thank Wazza
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Go and get the codes read.
Optimus_Prime
42
WA
'06 Clubsport R8
Had similar... would struggle to start like the battery was flat, flash up check engine/contact dealer or whatever just for a second, then stuck with ESP OFF & running rough (tended to do this only after it had been run/warm engine). I took the intake off & cleaned the MAF and throttle body whilst doing something unrelated & since then its all but gone. Assumed maybe had too much oil on the K&N and some crap has somehow got on the MAF and/or throttle body OR the wiring/plug to the MAF was dodgy (pretty sure if you leave it unplugged it will flag the ESP OFF and run rough). Worth a try if you havent sorted it already. This is on an '06 R8 @ ~120k btw.
Daptoid
Dapto, NSW
VX S PAC Dual Fuel
Hi mate did you work.out what it was my ve omega done the same thing today?
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
dying battery can also cause this, mine did similar, battery was nearly stuffed, starting feels a bit slow may be a sign, once going voltage comes up and no probs (everything runs on power) get your battery tested
r4q2
52
Gizzy, NZ.
07 VE SV6 Ex Police Pursit
Hi I've just had this problem today, going to get it checked out asap, but from what I've found after search the web it could be a number of problems, battery, MAF, etc.
I'll post up my out come once it's sorted.
K-Man
VE SSV
^^^ Almost Dead battery for me. Had the exact same symptoms.
Zerone_V
Lexus IS350 (SL)
Fuel Injector for me.
Best to get the codes read, otherwise it could be anything engine or transmission related :eek:
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
also on the power/battery issue (if it is) there is a connection at your jump start post (I believe) and then runs to starter, this can be loose and cause power issues
'ssv'
41
VE SSV MY9.5 M6 UTE
How about the same engine light/esp light flashing but also a terrible knock sound after it kicks over. Like a rod is about to come through the block.
This happened to me last week. Hoping it's not a full rebuild but it's not sounding good.
