Check oil light after oil change
Discussion in 'VE Holden Commodore (2006 - 2013)' started by fcm, Jan 14, 2012.
  1. fcm
    fcm New Member
    VE Commodore
    G'day , I own a 2006 VE Commodore series 1. Changed the oil yesterday putting in roughly 6.5l of penrite HPR5 and changed the filter. I also done an oil flush. I have the cartridge filter that sits in the metal cannister which i filled with some oil before filling through the oil hole. Today im driving and get the check oil light. the 3 hole dipstick is just above the 2nd hole. Whats the drama ? What should i do ?
    Cheers.
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    well for a start ve alloytecs hold approx 7 litres.
    did the light come on straight away? and by oil flush do you mean engine oil flushing additive was used before you drained the oil?
  3. fcm
    fcm New Member
    VE Commodore
    The light came on three times the day after. You are correct about the flush. I added it to the oil ran it for 15 minutes then drained the lot.
    Cheers.
  4. Boonz
    green 355 VG ute
    How many k's has your car done? Could of dislodged some carbon from the heads an its blocking the oil pickup
    Sent from my MB860 using Tapatalk
  5. fcm
    fcm New Member
    VE Commodore
    190, 000 kms. If it is carbon how do i fix it ?
    Cheers.
  6. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    Early VE V6 only hold about 6.7litres.
    Do you mean the red oil can light? Generally means low oil pressure. If its a bit sludged the engine flush has probably dislodged some sludge and its partially blocking the pickup as said above.
  7. calais06
    calais06 Donating Member
    Sydney, NSW
    VE Calais MY06
    My early alloytec is full at around 6.9L I oil.. (just above the 2L line on the second bottle of oil left).
  8. oska
    oska Active Member
    vx custom 600RR
    if you recently bought i'd guess oil changes where not done on a regular basis
    i've seen this on engines with 100K full of sludge
  9. fcm
    fcm New Member
    VE Commodore
    OK, so how do i get rid of the sludge ??
    The check oil light didn't come on again after lunchtime yesterday despite driving the car.
    Is it safe to drive ?
    Cheers.
  10. RiCeY
    Australia
    How did the filter look when you pulled it out?
    When you put new oil in does it get dirty pretty much straight away or does it look clean after running the engine?
    It should be safe to drive if the oil light isnt on and the engine isnt making any abnormal noises.
