Check oil light on after oil change
yowiie
Glen Innes NSW 2370
VX Clubsport
Just changed the oil in LS1 and went for a drive to shop’s and check oil light came on over a distance of 1.5k
light-never came on prior to oil change, oil level is correct and new filter installed
vr304
Auckland, New Zealand
2007 ssv manual
As above its most likely the oil pressure sender which is located at the back of the inlet manifold
yowiie
Glen Innes NSW 2370
VX Clubsport
It’s odd that it would fail after an oil change, I was under the impression the engine light comes on if the sender fails
vr304
2007 ssv manual
Yea true the check engine light came on in my old vx ss when the sender went bad, need to get the codes scanned and see what it comes up with
MiKExAUS
Sydney NSW
VX SS A4 Series II
Oil pump? Motor making any weird noises?
Jezza
Now with LS1 power
South Australia
WH Statesman International
See if you can get someone with a scan tool to check the oil pressure reading at idle once warm it should be about 200kPa. It could be that the reader is faulty and needs changing but see if you can get a reading on the oil pressure
