Thiele07
- Nov 10, 2018
- 4
- 0
- 1
- Age
- 31
- Location
- Port augusta
- 2008 VE SS 6.0L
2008 VE SS 6.0L
So about 5 weeks ago my check oil light would come on when in idle e.g stopped at traffic lights but only once the car had been driven for about 15/20 minutes prior i would either take off or just put 700 / 800 rpm on and it would disappear so i assumed oil pressure was dropping.
Took it to a mechanic and he said yep oil pump so while it was in getting a new oil pump both sensors got replaced, oil changed and new filter.
Sump was pristine so i was told.
Up until about a week ago we thought the problem was fixed but then the same thing kept happening again started off every now and then but then become more frequent but only when was idling so took it back in and ended up having all the o-rings under the valley cover replaced as that was his next option if the problem kept happening, they were very brittle and just crumbled in your hand when removed.
So things were sweet up until 2 days ago....
Problem is back
I have heard of cam bearings but i have no chirping or noises under the bonnet, lifters sound fine so just wondering if anyone has had the same problems its draining my wallet very bloody quickly 2500 spent already and not keen on spending much more.
Any ideas on the problem would be awesome
Problem is back
