Check Oil Warning
JessM
VZ Executive Wagon 2005
Hi guys,
Got my car service recently, guys said there was a slight oil leak so he degreased and said to monitor.
Been having the "Check Oil" beeps and warnings every-time I turn on the car now.
Oil is full though as they put in 6 odd litres.
Anyone had this issue?
Coast_Calais
sick of the idiots here
gone
varies
are you guessing it's full cause they said they put in 6 litres, or have ya checked the dipstick?
Darcon666
Evil is always around you
At home
www.gfy.com
The Wife
V6 or V8??
Probably the Oil pressure sensor/switch however I am no mechanic and others could have a better idea.... I would be taking it to someone who can hook it up to a tech2 and check the codes being returned.
Good luck.
JessM
i have checked it yes.
Coast_Calais
gone
varies
probably a sensor/connector, doubt it'd drop six litres, and besides you checked it...
doubt it'd be a pressure issue also...
maybe something didn't like getting a bath and degrease.. water...
wattles
Mt Isa
Vz Sv6 04
i got the same after the dealer changed the oil? i just dont worry about it coz its full? lol
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
lol, faulty pressure sender.
Pressure swtich throws an engine light not an oil warning.
peterrobo
Engadine NSW
2006 VZ Calais 190kw
"Check Oil" warning is definitely an indication of low oil pressure being sensed by the ECM (Engine Control Module). You said that mechanic told you it had a slight oil leak so he cleaned the motor down!!. Could it be that the oil pressure sender under the oil filter is the point of the oil leak? If this were the case then the switch (sender) is possibly faulty and causing the warning message even though the oil pump is pressurizing the oil galleys correctly. If you actually had low oil pressure you'd notice the lack of performance and engine would be noisy particularly in the valve train area. If you can't resolve the issue yourself take it to another mechanic who knows what he's doing and get it corrected.
db_notso
diagnostic technician...
33
sunshine coast, qld
vt v6, mods(susp brakesetc...)
+1 oil pressure sensor
with heating and cooling they develop a leak past the internals to the pins coming out of them and hence dont read properly anymore as leaking the pressure its trying to read
sometimes the sensor inside disconnects from the housing too
i have pulled some apart as i wanted to know why its such a common problem...
this check engine oil light in vz for this fault will often also have "service vehicle soon" come up but not every time
both of these lights on ipc require a code to be set in the ecm so need to get an obd2 checker or scantool and see codes is
then replace that part
heres one i bought recently after being sick of bringing stuff home from work
workls great shows all data for engine and can clear and read engine dtc codes
Maxscan Autel VAG405 VW Audi Scanner Code Reader OBD2 (eBay item 280593955076 end time 23-Jan-11 16:56:26 AEDST) : Cars, Bikes, Boats
and for this much why not huh?
JessM
Got in touch with local holden dealer/service centre. quoted $79 for part and $130 for labour. Does this seem a little high to anyone?
