Check Powertrain After Installing Manifold Insulators.
MC_WERKS
Roleystone, Perth
VZ SV6 A5
I installed Mace manifold insulators this arvo. Job went smoothly.
Headed home via the servo, Car is running fine, no lights or warnings yet. Then heading home from the servo I get Check Powertrain Msg. The car still runs fine with no issues just the powertrain light.
Now first question:
Would this be related to the Insulators? Filling up at the servo?
Any thoughts?
Cheers,
VZ_commo91
Ipswich QLD :(
2006 VZ commodore Acclaim
Have you left something unplugged by accident ? Bumped something out of place ? Just go through and make sure everything is plugged in properly. ( as the obvious answer )
If not it may just a coincident and something else has failed. ( like I got that warning after driving though a puddle of water, Turned out to be the Oil pressure sender. )
wattles
Mt Isa
Vz Sv6 04
i just did mine and went for abit of a drive and havent had any problems yet man
MC_WERKS
Roleystone, Perth
VZ SV6 A5
Went through and checked everything, Going to get it scanned today to fint the problem. Hopefully I have missed something and its just a quick fix.
ashbox
back in black
The Car
something black
unless u have a leak somewhere
sp001in
vyma100
QLD
VY ute
I have heard the MACE throttle body can some times set off a fault code on the powertrain due to throttle positioning and heaps of other factors. but manifold spacers are a first.
make sure you post up the cause of your problem once you find out what it is
PaulSV6
CHE Tuned 156.8rwkw
Castle Hill
VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
Most likely tats all it would be! As long as u weren't having any issues before hand.
MC_WERKS
Roleystone, Perth
VZ SV6 A5
Found the issue to be a cracked PCV hose at the rear near the barometric sensor, It was cracked beforehand but didnt open up until I removed the Plenum. The Intake has got fuel consumption down to 10L/100km combined which is awesome.
