Uldis Esots
Stosey
Hi guys, first time here and hope you can assist. I've had a VZ Acclaim for approx 6 months. Initially it had issues with the engine cutting out & check powertrain warning light coming on- I took it to a Holden dealer and they found a loose vacuum hose. Problem fixed. In the last month it's started cutting out again, approx every 200kms, usually whilst sitting at the traffic lights or at low speed. I took it to a Holden dealer and their checks couldn't produce any fault codes and road test couldn't fault it. A friend has suggested possibly a cracked exhaust manifold, although I'm guessing an injector problem or something electrical...any ideas? The problem has really only been at low speed or idling. :cry:
PS, the dealer has checked the oxygen sensor and couldn't fault it.
