Checking 6 Speed Transmission Fluid
stooge
wa
Turbo Alpaca
this may also help
Dayvo
Because i can
67
South East,Victoria
VE SV6 Series 2
The main thing is to remember NOT to turn your engine off while you are checking it or you will dump tranny fluid all over the floor
YeahNahJack
QLD
VR Executive
Hey guys,
So recently the transmission fluid on my 2007 VE Calais V6 auto 5 speed has been leaking from the point where it attaches to the radiator. I'm fixing this leak today, although I will also need to top up the transmission fluid. I've read through the thread and checked under the car, although none of it is making sense to me. Is there a diagram of where the trans sump plug is, how to remove and what type of pump to put more fluid in?
Any help would be much appreciated :)
redvxr8clubby
Sunshine Coast QLD
VX Clubsport R8 & VE SS
Hey guys,
See post 11 above the photo 6.4 shows 5 speed transmission plugs, You would need a syringe type pump to fill via the filer plug. The syringe type pump is something like a bicycle tyre pump. I bought one many years ago, if I recall correctly it was referred to as a "wheel syringe" I don't know if that term is still used, or I my recollection of that is correct.
YeahNahJack
QLD
VR Executive
Thanks mate! I'll give it a try
Australia
VS Executive wagon, VE wagon
Thanks stooge, I've been looking hard to find the info you put in #11.
I doubt if all the service places I've taken my car know the correct way to check the transmission oil level.
My car sometimes won't change up, after hard acceleration, more when it's cold. Do you think it could be low on oil, like someone at service has let too much out?
Any help would be great.
Anyone else had this problem with the series 2 V6 3L Sportswagon?
(Mine has just clocked 190000km)
snortings
Queensland
MY15 SV6
There is a "Performance Mode" that I've heard others say on this forum when the car is in Sports mode.
If the computer thinks that you're giving it a flogging and that you will again very shortly it'll hold that gear so it doesn't have to change gears again. It goes away eventually when the computer thinks you don't need it again.
Don't quote me on that as I'm not sure if it's correct, I've just seen a lot of people say that.
TANK 2.0
VE SS
Are those auto transmission additives any good to use, or are they harmful?
PS do you even have access to add them?
peter195863
65
2/6 crestwood crt kurwongbah qld
2015 vf sv6 commodore ute
You should check the level at least once a year.
To do this. Go for a drive from Cold for around 10Mins or so. Dont give it too much. Just drive it normally.
Go back home. Put the car into Park and Put Hand Brake on. Leave Engine Running.
The car must be on a level ground. (The Trans Fluid needs to be around 30-50Degrees (No More or No Less). Thats why you only drive the car for 10mins or so.
Grab a Number 14 Spanner I think. or 15. Somehow you need to slide under the side of the car and undo the Trans Sump Bolt which is located on the Rear under part of the Trans Sump. It wont drain your trans as it has a tube with that sits at the full level of the fluid.
You should get a slight trickle of fluid coming out. If you do, put the bolt back in straight away. The fluid level is good.
But I must say, its a bit of a prick as there is not much space to slide under the car. If your a skinny person, should be OK. And also you can burn yourself on the exhaust (In my case).
I though next time I might jack the front and rear of the car up at the same height which might make it easier.
IMO Holden should have put a Dipstick for the trans. All they had to do was put a lockable Dipstick to prevent tampering under warranty. If the lock is broken, it voids the warranty of the trans.
At least after warranty has ended, you can break the lock. Mercedes had this same principle.
The only reason holden never put a dipstick was to prevent people from putting the wrong fluid in, or overfilling it, as most people dont know the procedure to check and fill the trans.
Not for Engine Bay fires. Thats just rubbish. This never happens with other cars so why should it happen to Holdens.
do u drop the plug on the pan of the auto . i pull the plug for the filling purpose is what i've read in my workshop manual
