checking engine oil and transmission oil level correctly....
zskinner
WN CalaisV 6.0L
hey so i have just been doing some checks on all the fluids and oils in my vp v6, but am not 100% sure the correct way to check engine and transmission oil. i went for a small drive to get the heat up to normal operating temperature, then with the car running at idle, i checked the engine oil, and it sat just below the maximum mark, then i checked the transmission oil and it was sitting just below the minimum mark. i then turned the car off and re-checked the oils and with the car turned off, the engine oil was a tad ABOVE the maximum mark, and the transmission oil sat just below the MAXIMUM mark. which readings do i believe? should i add a bit or drain a bit of engine oil? and should i add just a little bit or should i add alot of transmission oil? cheers for any feedback :thumbsup:
db_notso
diagnostic technician...
33
sunshine coast, qld
vt v6, mods(susp brakesetc...)
check engine oil hot or cold with engine stopped
when hot if level is correct may seem a few mm above full this is ok but a cm over the full mark is bad
transmission fluid
check with engine running and go through every gear manually for two seconds then leave it in park and check it should be be close to the maximum mark
should be checked hot but when first changing fluid check cold drive it then recheck
zskinner
WN CalaisV 6.0L
sweet thanks heaps mate ay, just what i needed :thumbsup: legend
bubbada
victoria
91' VN Commodore
transmission fluid
select is it P,R,N,[D],D,2,1 then Select park or 1,2,D,[D],N,R,P?
EYY
VS Statesman
Drive it until its at operating temperature and then park it on level ground with the engine running and in park, clean and reinsert the dipstick to check the level.
