Best time to check engine oil is after a run long enough to thoroughly warm up the engine. Park on level ground, switch off, wait 10 minutes for all the oil to drain back into the sump, then check the dipstick. (Pull dipstick, clean with non-fluffy rag, insert dipstick fully into engine, then remove again and check reading.)
Best time to check engine oil levels. Cold? Warm? I find that with the dipstick on the 2013 vf Commodore is hard to get a decent reading.any advice/tips appreciated cheers.
I just check it when it’s cold before I go anywhere. I’d much rather find out I’m low on oil before I drive the car than after I’ve taken it for a long drive to warm it up!it does not matter if you are just checking it, hot or cold you will be able to see if you need to add more, just dont check with the engine running.
He did ask about 'best' time. I.e. when is the reading most accurate....
