Cigarette Light Socket - loose
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by webwombat, Nov 30, 2007.
  1. webwombat
    webwombat New Member
    MY10 VE SS-V wagon
    Anyone know how to fix a loose cigarette light socket - pain in the arse position under the tray - 2001 VX commodore
  2. Rishy
    Rishy Si Vis Pacem Para Bellum
    Mirrabooka, WA
    2003 Nissan GU Patrol
    i believe it screws in.
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    I think the back screws on sandwiching the trim panel between the lip of the socket and the retainer.
  4. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    yes, there is a big nut on the end that holds it tight and it has probably come loose. You have to remove the console cover to get at it. Undo the 2 screws either side of the socket then lift the cover from the other end using a bit of force because it clips in.
  5. s_ikari2015
    s_ikari2015 Fun IS easier with an 8
    Australia
    '02 Monaro V2 CV8, '83 Subaru Sherpa, '87 Sherpa
    I was on the right track in the faults thread... but yeah..
    You'll need to remove the radio to take the gear surround panel out, then you should see these two screws that hold the "ash tray/pocket" in place. I remember that now. :w00t:
  6. accentstencil
    Eschol Park, Sydney
    You will not need to remove the radio, you only need to remove the console surround as I described.
  7. Rishy
    Mirrabooka, WA
    All i did was use my fingers and twisted the socket. didnt remove anything.
  8. webwombat
    MY10 VE SS-V wagon
    I am going to try that trick and report how I went
    Update - too bloody hard to insert my fingers and twist the damned thing - better off taking it holden dealer
  9. accentstencil
    Eschol Park, Sydney
    Give it a go yourself. Just follow the instructions in my fist reply and then remove the 2 screws holding the storage compartment and then your in there. Just tighten the big nut at the back of the socket. Save money and inconvenience of taking it to Holden.
