clamping brake lines when removing clipers to paint
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by pow3rslave, Apr 24, 2009.
  1. pow3rslave
    pow3rslave DoNothing Member
    eastern subs, vic
    VP 5.0L
    right now i've got shiny red rear calipers but ghetto looking scummy front ones.
    i figured i'd take them off to do a decent job like i did with the rears, but i'll have to take them to my parents place to paint them.
    when i take them off i was gonna clamp the rubber lines with some of these
    so that the fluid in the system doesn't absorb moisture.
    would this cause any damage to the line?
  2. Leebo
    Leebo New Member
    89 VN
    When you do this you could as an option disconnect them and and bleed the system while your at it for slight better braking performance if they haven't been done in a while.
    When you have them off don't let the rubber pop out or that won't be fun to put back plus find a clamp that will allow you to have it on while you paint it if possible
