Clean your MAF
immortality
Staff member
Sth Auck, NZ
if your car has a MAF sensor, clean it. it takes 15 minutes and the difference can be like black and white. this is especially true if you run any sort of aftermarket oiled filter.
to cut a long story short, the missus car was slowly getting more sluggish, throttle response was getting worse, fuel economy was dropping like a brick (not really but it sounded good :p ) this was all accumulative over a long period of time so wasn't noticed.
when i removed the MAF sensor one of the 3 Hot wires was black with crap, the 2nd was approx 70% covered and the 3rd maybe 20%. there is proper MAF cleaner that can be purchased from your local automotive outlet. otherwise use electrical contact cleaner. me, i didn't have either so i used some carb cleaner, then i blew it out with LOW pressure air to ensure all the solvent had completly dried off.
first start was quicker, don't know if this was related to that problem, as soon as i gave it some gas it moved, shock horror:D pulled out of the street (rolling)i gave it a little gas and she kicked down a gear and went. previously this would have required a fair amount of throttle to achieve the same thing. long term fuel usage sat at 13.6ltrs/100km on the trip computer. i have reset so we will see what happens there
happy cleaning:thumbsup:
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
nice now just to get that new brake booster in your car now aye.its allways good when you find a simple fix.as far as im aware the frequency MAFS arnt actually hot wire like the old vl'sL they have a chip in there that senses the air draging over the wires when they get covered in crud they get thicker and stickier meaning they get pulled on harder by the air flowing past them pulling harder on the chip.but all in all allways good to clean them.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
if you are meaning on youre VR there isnt one on VR .VS upwards
immortality
Staff member
Sth Auck, NZ
after having a chat with Steve for MACE, apparently this is also a problem on cars with standard airfilters. definitly worthchecking.
DannyboyDS
Just hand me the pliers.
VS Berlina
someone should tell CXCXCX....... he is having fuel consumption issues.
padrickz88
Rick =]
sunshine, melbourne
www.facebook.com
VN V6, nothing special
its located on your intake piping from the airbox to the throttle body......
might have a look at my mums on her vt, her economy isn't great...
immortality
Staff member
Sth Auck, NZ
any pics of this item and where it is located on a VS please???
it's fitted in the intake pipe, just after the filter box. gotta undo 2 hose clamps and remove 1 plug at the bottom.
when cleaning be very carefull. the wires are very thin and you'll be ****ed if you brake one.
from now on, i'll be cleaning mine when i do the oil change. should ensure no further problems in that area
