MRVX2U
I have just pulled my Iac valve out and the tip is pitch black what's the best way to clean it?
buy a new one from Holden. At least check out the price of one, you may be surprised.
I've heard that. It must have spun round heaps of times. That was over 100,000kms ago. No issue.no way use a wire brush, the brass cone is mounted on a plastic screw,that moves in and out, if you turn it with a wire brush then it will run incorrectly.you want clean engine oil on the screw in and out bit.
