Cleaning K&N filter
pando666
milk comes in 2 litres
sydney
vs exec
cleaned my panel filter the other day I used almost 1/2 bottle of cleaner and only used 29ml of oil,kit will clean 2x filters oil will do 6-7 recharges. So, my question is can you use another type of detergent(cleaner), say dishwashing liquid etc, instead of the K&N stuff?.
social
Ute Finatic
South Aus
2012 VE Thunder
hey mate, when i had a K&N filter in my vn, the rectangle shaped one, to clean it, i gt a bucket and rinses it thorougly with petrol then just let it air out to dry, thats a cheaper alternative.
Chirpstr
A new project attack
VR Berlina M5, VP M5
Degreaser, then wash out and dry, then oil with a litte WD-40.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
hot soapy water is best can use dishwash all good.
DannyboyDS
Just hand me the pliers.
39
VS Berlina
I just use the K&N products and they seem to last, I havn't run out of my first batch yet, been cleaning it every 10 thousand for over a year, then again, I give it a good rinse in the sink too.
Cobez
LS-EXUAL
39
2004 S2 VY SS Ute
WTF?! Dude, i bought a K&N cleaner kit a long time ago, you DO NOT need to use half a bottle in one clean on your filter. You are supposed to do one coat of cleaner on your filter (not go nuts with it, just spray it lightly over the filter), let it soak, rinse the filter, let it air dry, then spray a light coating of oil on it.
Overcoating it with oil will decrease it's ability to flow more air as thick coats of oil will block the small holes in the filter which allow the air through.
I wouldn't advise using any detergents on it such as dishwashing liquid etc, it may cause the filter to dry and split etc. If you run out of filter CLEANER, just thouroughly clean it under running water, let it dry then oil it.
NORTI
Radelaide
Wildtrak
I seem to be using roughly the same % of each bottle, cleaner & oil, I think maybe you need to re-read the instructions on the bottles.....
sweefu
VY Berlina V6 / R31 Skyline
hey i wouldn't use petrol it deteriorates the filter's fiber, use kero as its safe for the filter.
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
was gonna suggest the same, if you got one of those kero tubs at work just wash it in that as it wont dry it and it will leave a oil behind on it if the drum hasnt been changed in a while.
greenacc
Searching for the billion
VE Berlina
or get a lukey filter that you can just put the hose on
