cleaning plenum chamber
casper0
sydney
vx commdoore
heys guys am planning to clean inside the plenum this weekend and i was just wondering should i block the holes while am spraying carby cleaner? other thing is bout the plenum gasket do i have to buy a new one or reuse the old one? last thing i know that the bolts for the plenum are hex ones can somebody tell me what size are they?
any advise plz.
thanks
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
From memory the its a 6mm allan key and 10mm bolts to remove the plenum from the manifold.
They're O ringed so you can re-use them. You could also use a little gasket silicon to make sure.
Use some good carby cleaner and a stiff brush. The burnt oil sticks like **** to a blanket.
Fletch_QLD
Brisbane Bayside
VU II SS
Some photos of your progress would be good casper :)
madsav
your ass
your ass
You could always do what i did, after removing the manifold in a WELL aired out area use mr muscel oven cleaner , i know sounds nuts but it cleaned my old commodores manifold up really easy
Oww and dont forget to have alot of rags to clean it up
casper0
sydney
vx commdoore
thanks anyway mates, i have read in other thread that removing these bolts with allan key is a no no. using a hex is a yes yes lol. anyways i dnt want to remove the plenum from manifold at all. just wanna clean inside and arround the holes only but somebody told me to cover the holes so the **** will not go inside the manifold runners. any advice?
lol for sure i'll post some pic when done no worries.
soop
Banned
Smithton, Tasmania.
I've been told that oven cleaner contains caustic. Alloy doesnt like caustic much.
That said, i've used it on severly corroded carbs before and not had an issue. Just thought I'd throw it out there :D
Nah, if you use the right Allen key it works fine. I could have sworn they were allen key heads anyway.
I would strongly recomend removing the plenum. You don't want that **** running down into the motor. It wont really hurt it, but it'll be a prick to start and probably not want to run right for a bit.
acarmody
Donati..Whoa Green
VX Berlina
I've always used an allen key and never had a problem.
Just stuff some toiletpaper or rags in the runners. Probably unnecessary but why not
casper0
sydney
vx commdoore
so mate if i removed the plenum from the manifold do i have to buy a new gasket for the manifold?
zapper-l67
LS# Eat One Today...
Western Vic
VX Calais
where did that other thread go Soop..
I was just reading all the crap and it disappeared.
