Clear oil leak
kummo
VR Statesman
G'day all,
I have a clear oil leak under my vr statesman 5lt. At first it was a small drop the size of a 10 cent coin, But today I noticed spots of it around the front right wheel arch and down that side of the car even on the back of the car.
what do you guys recon it is? Any help is appreciated.
danja
Swerves for gay koalas
CBF 250 and a Levin ZR
Brake fluid?
Start by checking all your reservoirs in the engine bay, then get under there with a torch and see if you can find the source.
Zuicider
Banned
Stonedville
Set of thongs
yerp danja is on fire, brake fluid it is
kummo
VR Statesman
Cool thanks I taught brake fluid was red? I know with out looking at it its hard but where do you think it might be coming from?
Zuicider
Banned
Stonedville
Set of thongs
motor oil is yellow to black, trans is red, powersteering is red, brake can be yellow green and blue. aircond is like a green, diff is yellow red and blue also
kummo
VR Statesman
ok no dramas thanks for the info
danja
Yep, what he said, plus on top of that brake fluid is one of the only fluids that doesn't seriously discolour throughout it's life (well, that and powersteering, which is usually red).
Brake fluid is most commonly green, and sometimes now clear.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
If it's only a spot it could be any colour - the colouring of all oils is faint and a spot is only a few microns thick so most oils will look clear. Brake fluid strips paint. So all you can do is what danja says - look all over the car with a torch and check all fluid level.
