RobboVl
VL REPPIN'
tinted be using a thick as black marker. works a treat. needs to be re done everynow and then. i redo mine maybe once every 2 months, but it isnt out in the sun or rain much so it lasts longer.
strongly reccomend it if you arent keen to spray tint - risking illegal.
if the marker needs to be removed i have used biemerpac alcohol wipes to tidy up bits where i screwed up. after a few times you get heaps better at it adn it only takes 5 mins to do.
What sort of marker did you use to go over the lights with man?
Was it a 10mm artline one?
I cant get over the fact you used a marker to do that.
hahaha
