clicking noise / wipers go and arial goes up?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by DannyboyDS, Oct 27, 2007.
  1. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    OK last night a problem started with my car.
    I was disconnecting the battery and accidently bridged + to the body :bang:
    Now ive got a clicking noise from just below the cluster (BCM?) from a little black box there. The wipers set to intermitten when the car is on acc now and start firing the second the key is turned.
    I tried disconnecting the battery over night in a foolish hope of "cars fix themselves"
    am i up for a new bcm? pulling the wiper fuse out halves the clicking noise too.
  2. DannyboyDS
    VS Berlina
    ok so i got a new BCM, took forevrer and in all the places I looked I finally found ONE that was the correct BCM.
    A found about 50 LOW and about half that in MID and then finally a LUX
    Anyway It did not have a key/keyhead with it. what are my options do I need to get the rip off merchants at holden to link the key and bcm ?
    what do people do when they lose both of thier keys?
    *Edit*
    http://forums.justcommodores.com.au...is-bcm-into-berlina-trip-holden-required.html
    Answers all of my questions in one hit, I need Holden to link my ECU and Key to the BCM.
  3. cruzn
    cruzn Member
    vr Commodore
    Your old remote key head is no good with your new BCM. You need to get a new remote programmed to your new BCM. Locksmiths charge about $270 for this from memory.
    Note before doing this, overide the security system with the timmed overide, start the car and make sure everything is working properly. I am saying this because i did the same thing on a camry and my wipers also went spastic. Problem turned out to be the wiper switch though.
  4. DannyboyDS
    VS Berlina
    Cost $300 odd all up, but everything works again.
    Note to self, don't short battery to body of car. I hear a plastic bag over the tool being used can be a big help.
