Clicking when i turn corners?
MGNick
VS V6 Commodore series 2
my car has been lowered and could be possible that my spring has come loose or something i have been told.
but what else could it be?
and will it be expensive to fix
MGNick
yeh good call man
Jesterarts
Your freedom ends where mine begins
39
2010 Nissan X-Trail ST-L
Hmm... does it happen when you turn one way or both? Does it go away if you apply the brakes?
Is it a ticking or a knocking? If you've got spring issues they would manifest in more of a knocking when running from lock to lock or going over bumps.
If it's a ticking when you're turning one way, I'd be looking at a wheel bearing or maybe a loose brake pad?
_R_J_K_
Zenki S14
Checked your swaybar links?
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Has the car been lowered with new springs or the old springs cut?
Adds_05
Central Coast, NSW
VT SS 5.7L
strut top bearing? had it happen in my vn when i lowered it and when you would turn the wheel it would click its head off
ruffiano
Ballarat
VZ SV6
If it's the front... CV joints? Will click when the wheels are at full lock...
Brett_jjj
Tamworth NSW
vs commodore
Commodores are rear wheel drive therefore dont have cv joints in the front.Check the front wheel bearings/hubs for play/looseness.Push and pull the wheels in and out at the top and bottom of the wheel.Jack it up to do this.It should have the tiniest bit of movement.It could also be the brake disk, brake pads or seized brake calipers not retracting the pads from the disks properly.
