Have just had the same issue in manual control heater - a/c system with the vacuum defaulting to the screen when climbing a hill. Would like to thank those who contributed to resolving the issue, and like to share what was the exact cause in the hope it may save someone else the trouble. I was able to detect the demister vacuum actuator being faulty and causing the vacuum leak "under load" Fault was also slightly evident when mode was on face/floor and floor modes as well. There was a slight amount of air at the demister as well. After dropping down drivers side cover under steering wheel, then removing RHS console cover held by 2 Phillips head screws at front, then popping the clip at rear, the panel comes out and shows 2 actuators (both 2 stage actuators & are identical part) 1 controls demister and floor and other controls face modes. The demister actuator with the Pink and Orange vacuum lines attached was found to be faulty. To test this in place, when face/floor was selected the rear Pink line applies vacuum & pulls the actuator arm in 1/2 way, and orange line applies vacuum to the second stage and pulls in the actuator arm fully. If the actuator diaphragm is leaking this second stage will not happen and a small amount of air will go to the screen demister, which also will be the case when the engine is put under load, as the vacuum reservoir has all leaked & engine is too busy supplying its own needs when more power is called for from the motor. As mentioned in one of the posts, remove the front securing screw and unclip the actuator arm from the duct lever, pulling gently towards you will release the back securing point, remove the actuator and complete the test by sucking on the rear nipple(Pink), the actuator arm should start to pull in & hold, if okay then do same on side (orange) line and should also want to pull in. If any one of these doesn't pull in it means the diaphragm is ruptured and actuator is RS - Replace unit to rectify fault. Refit and replace covers and screws.
Hope this helps others as much as it did me - the part that is pictured in one of the posts is the correct part
Holden part # 92140681 cost approx $70AUD
