pjr62
- Nov 5, 2014
- 2
- 0
- 0
- Location
- Mt Gravatt
- VF SSV Redline sedan
Hi all, picked up my VFSSV Redline April 2014, have had the following issues
*Bad smell coming from AC Holden have replaced condenser & drain hose, however took three weeks for them to find what the smell was after masking smell with air freshener and hoping I would go away
*Rattle in RHS front door fixed by dealer
*Mylink forgets I phone, completely random and at the most inconvenient times unable to fix
*Climate control seems to not have any correlation with outside temp and inside temp, example it can be 25' according to the car outside, comfortable temp inside would be 22', at this setting the AC will reduce the apparent temp in the car to a point and then appears to increase, I counter this by reducing temp on control to 18', at this point it should be cold but it aint so I reduce it further until it is cold, other cars I have driven recently 2014 VF evoke climate control worked fine set it on 22' never touched again during the two weeks I had it, dealer has checked it out, upgraded software no change and I have now been told it is what it is.
This very much a first world problem but when your forking out $57,000 for a car you expect things to work.
This is my fourth SS commodore my last one was a VE SSV no issues with that car at all
I had high expectations for the VF and feel let down
Anyone with similar issuies
