Clunk underneath.
Clubsport5972
Timaru, New Zealand
VE Commodore Omega 3.6l
I’ve just done my caster arms, lower control rods, and tie rod ends. Every time I turn or hit a bump there is a noise from underneath, similar to a brass rod hitting another brass rod. Has anyone had anything similar before I take it into the garage to get looked at? Any ideas?
greenacc
Searching for the billion
VE Berlina
Sway Bar bushes?
syked
Donating Member
2011 WM Caprice
Or sway bar links or tie rod ends.
Also check the ball joint nuts are all right.
_R_J_K_
Zenki S14
Did you get a look at the castor wahsers at the front of the car when you replaced the castor rods?
