Promotec
- Mar 7, 2009
- 97
- 1
- 8
- Location
- Gold Coast Queensland
- 2010 VE Commodore International Dual Fuel LPG / UL
I went to start the Car today (VX Commodore 2001 v6 eco 3.8 duel fuel)
Turned the key and just heard a clunking really loud as thought the motor was seized *Oh F**K*
tried a couple of times same result, got my wife to turn key as I watched the motor same it wouldn't turn over like it was seized
the car had been used 3-4 hours earlier no problems went well, no noises or anything strange.
I talked to a friend who is a mechanic he couldn't get over to have a look he suggested first check the harmonic balancer
I removed the serpentine belt and examined the harmonic balancer all looks fine rubber between hub and outer metal ring looks fine
no obvious movement when trying to rock side for side etc.
I put a large spanner on the harmonic balancer centre nut to try turning the motor over manually it turned fine harder coming onto compression
of course but would turn fine no noises (but turning the crank shaft by spanner I didn't expect to hear any really)
So I left the belt of and tried starting with the starter again and this time just a horrific grinding noise when the starter engages
so loud you would hear it a couple of houses away.
To me it sounds like the starter gear grinding against the ring gear rather than engaging properly
I have spoken to my friend again he suggested broken flexy plate but Im not sure if that sits right with me
as the car doesn't even get to start as the sounds so bad I wouldn't be really game to keep cranking to try and start it.
My friend thinks that the starter shouldn't make a noise once the starter throw out gear is engaged may be after starting if the retractor spring is broken
but not while engaging.
I put the car up on stands with the idea of dropping out the starter motor to examine the throwout gear for clues, but I have been really sick lately
and laying under the car made me nauseous I got out from under the car and vomited profusely, from my sickness plus the stress and panick of my car being
stuffed as I live rural and we are dependant on it for transport being our only family vehicle
Has anyone encountered this before or have any idea what it may be
I have uploaded a wav file of the sound to my website it can be accessed here http://clairvision.net/noise.wav
