zeropalooba
- Dec 29, 2009
- 52
- 26
- 18
- Location
- Sydney
- VS Acclaim L67 manual
I was wondering if anyone has experienced problems with camber kits causing bolt holes to become flogged out.
Some years ago I installed low king springs at the rear of my VS Acclaim with camber kits on the inner bushes. I had a shop do an alignment (the car was never right afterwards, steered to the left like a pig). A noise has been getting progressively worse over the last year or so. It's a clunking sound like a metal bar hitting the sub-frame and it occurs when the rear suspension gets laterally loaded, i.e. going around corners, one wheel hitting a bump etc. To try and isolate the source, I disconnected the sway bar with no change, the shocks with no change. I even swapped the open diff for a sweet M80 LSD but no joy. What I have noticed, when I did my own alignment (got a much better result with a tape measure, seriously), was one of the bolt holes for an adjustable bush seems to be elongated a fraction. I suspect this is the problem. Has anyone else had this?
