Clunking Problem at about 75-78 Kms
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by benim2000, Mar 7, 2007.
  1. benim2000
    benim2000 New Member
    I'm not sure how long i've had this problem but at about 75-78 i think its the automatic shift sounds like it slipping and clunking.
    when i go up to 80ks the problem dissapears.
    any ideas?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Could be a faulty lead or plug, they have that effect.
  3. phoneman_nz
    phoneman_nz New Member
    VT Acclaim
    I had that, is it when the car tries to change gears ? turned into a miss, I have changed fuel and air filters, plugs and leads checked out the coils and it still misses. grrr
  4. benim2000
    yes i think its when its trying to change gears
    did it end up being expensive?
  5. phoneman_nz
    VT Acclaim
    Sheilded leads were arching to Manifold, removed heat sheild and that solved that problem, but now my problem has evolved, when the car is cold its fine, when it gets warm the miss is prevalent 1500-2500rpm is rubbish zone, if you dump the throttle then fart splutter blurt and then a backfire. not expensive yet, but will be if I can't find it. Getting frustrated. Not really sure what to do next.
