Cluster - Con 2 - Pulse GND/2 Pulse shorted, now no speed
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VS Omega, Feb 14, 2009.
  1. VS Omega
    VS Omega New Member
    VS Commodore Omega
    Hi all,
    In a follow up to my previous thread I actually have the cluster in my hand and the pins that shorted turn out to be Pulse GND and 2 Pulse (or possibly Pulse GND and Right Turn).
    What happened is the ribbon got damaged so I soldered directly from one point to the pin at the back of the cluster but didn't solder well enough and they made contact with each other.
    Now I'm just trying to figure out what I broke (must be something - speed alert doesn't show speed as well, only the ALDL cable shows it so it's not the sensor) and how to fix whatever "Pulse" is?
    Thanks heaps guys, this car's killing me :cry:
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Sounds like you need a very very fine point temperature controlled soldering iron. What I've done in your situation is to solder individual wires to the ribbon....maybe 6 or 8 separate thin insulated wires. then its more easy to solder the individual wired to the PCB instead of worrying about the ribbon and it's fixed spacing between wires.
  3. VS Omega
    VS Omega New Member
    VS Commodore Omega
    In the future I'll just be way more careful with installing the cluster so the ribbons don't get cut on the interior, but right now something else is broken :(
    Good advice with the fine point soldering iron though
  4. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    You may have fugged somthing on the speedo board id say. Can you plug it into another vr/s anywhere and see if it works. But given you got aldl reading then i would have to say its likely local to the cluster and more so the speedo itself.
