Cluster lighting issue
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by vpcomm92, Nov 15, 2011.
  1. vpcomm92
    vpcomm92 Banned
    victoria
    VP Commodore S2
    Hi,
    I'm having an issue with my cluster, it's really weird. I replaced my cluster to a level 2 last year, I'm not sure but I'm pretty sure it worked fine prior, anyway, when my car is off, or on ACC, the cluster lights up normally, handbrake light, check engine, battery, and if applicable headlights all light up, then I turn the car over, and all those lights disappear, my handbrake is still definitely engaged, and headlights definitely on, yet no cluster light? Anyway, I flick to high beams, and that icon shows while the car is running, and while off, but otherwise nothing, handbrake and headlights can be on but as soon as I turn the car over, those cluster lights are gone. Indicator cluster lights work while car is on or off too.
    So, what could it be? Clearly all the globes and connections work.
    Also, on a side note, my wipers work on INT and 1 fine, but on 2 they're the same speed as 1, but lag a little and sound like they're struggling. After a while of them being on they get a tiny fraction faster, ideas?
    Any help is appreciated Thanks
  2. vn1989
    vn1989 New Member
    maryborough
    vn executive series 1 v6 1989
    have no clue on the cluster but maybe ur whiper motor is just about buggerd and i dont see what could be causing ur cluster problems maybe a short some were
  3. FXST01
    FXST01 The Grey Man
    Perth, WA
    VP V6 Exec
    Sounds like your cluster is not getting enough power. If you still have the old cluster, compare the pinouts on the back with your new cluster and make sure the power connections are correct.
    Wiper switch may need a clean, they pull apart easily.
  4. vpcomm92
    vpcomm92 Banned
    victoria
    VP Commodore S2
    But If it wasn't getting enough power wouldn't they not light up at all with the engine off? And the high beam light and indicators light up on the dash while the engine is on. Hmm :/
