Clutch cable very stiff, how to fix?
Bellicose
New Plymouth NZ
TOW PIG
Hey all,
I knew the clutch cable in my VR ute was very stiff ie: hard to depress, but i didn't realise how hard it was until the other day when i was moving my cars around.
I moved my VN and then jumped into the VR and **** what a difference lol, the clutch in the VN is so smooth and easy to depress.
Does the cable need lubricating or...........?
cheeRS.
Pasticheny
I was thinking the same thing bout mine ute the other day.. I hav a heavy duty clutch but didn't think that would be the reason why it so stiff :s
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
They arnt real dear. Just by a new one and replace it. More then likely the cable has worn a grove in the anaconda and is sticking in it. You'll also spend less time just changing it then you will trying to fix the old one. win-win
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
Also have a look where the cable goes thru the bulkhead - the metal can flex and crack causing the cable to work at an angle making it very stiff.
flyreels
VY Calais
Thats what was wrong with mine so start there
