Clutch Shudder
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Drawnnite, Jul 15, 2011.
  1. Drawnnite
    2000 Vs Ute
    ok, this probably seems strange, but anyway. its a 5spd manual VS Ute (2000)
    driving along its fine but after about 1hr or when the car gets hot when i go to take off the clutch shudders really hard and requires a fair few revs to take off while letting the clutch out slowly.
    has anyone heard of this before
    could it mean the clutch is going, or has possibly gone?
    any fixes?
    thanks
  2. Cameron P
    Cameron P New Member
    Quakers Hill, NSW
    REDHOT VX SS
    Does it slip?? Seems like your flywheel is getting hot and possibly needs machining.
  3. jatsvl
    jatsvl NEEDS MORE POWER!
    vl exec wagon
    maybe the clutch master cylinder and line needs bleeding or replacing.
    if the clutch plate is stuffed it would slip.
    if it keeps shuddering then the flywheel will need machining, then you may as well replace the clutch at the same time.
  4. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Some possibles are: soft/broken engine mounts....oil on clutch facings....clutch plate friction surface worn down to rivets....hydraulic fluid line from master cylinder to slave mounted too close to exhaust causing fluid to boil....flywheel distorted (don't think you can machine these as dual mass)
    I hope it's simple as they can be expensive to fix, and I'd try and track it down soon.
  5. franck
    franck Member
    wamberal
    vr executive 5.0 M5
    have the same problem, not always but sometimes in bumper traffic going up a hill, spoke to a mechanic at work he reconds its the two piece tail shaft, he daid get a vl shaft and it will go away, think ill just put up with it
  6. Cameron P
    Quakers Hill, NSW
    REDHOT VX SS
    You can machine dual mass flywheels, depends on the condition though
  7. Drawnnite
    2000 Vs Ute
    thanks for that guys.
    i think ill take it to the mechanic and see what he also says, which will probably be book it in.
    and if its expensive to fix, its tax time so thatll easily pay for it =P
