clutch squeeking noise
krisjanik
34
vl executive
hey all wen my car is in nutral sometimes this squeaking noise comes from the bellhousing and as soon as u put pressure on the clutch it goes away and wen u pull the pedal back it goes away 2 wtf !!
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Not sure if your clutch is hydraulic or cable but it sounds like either the clutch release lever (inside the bellhousing) is not returning and/or the clutch release thrust bearing is dry.
POVRTY
building 5L VB TH 400
41
taree nsw
Wm L98 caprice
if its the vl in his public profile its hydraulic.
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
My vr had the return spring broken on the pedal and the throwout bearing was just hitting against the pressure plate fingers and squeaking.The spring puts constant pressure on the fingers at rest but that was a t5
