Clutch Suddenly Softer / Not As Rock Hard?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by social, Mar 12, 2009.
  1. social
    social Ute Finatic
    South Aus
    MY06 6.0L VZ Thunder(na naa na naa..)
    Hey guys,
    Did a fair bit of driving today, more than usual (about 150kms) and i noticed towards the end of the day, my clutch went from (as usual) 100% wat-the-fk-rock-hard to a hard press through to a soft follow through (if that makes sense). Just wondering if this is a bad thing or something? Clutch isnt slipping or anything and no mechanical faults to date so yea just doublechecking everything. Previously when i got the car, i tried to adjust the cable but all it did was change the height of the pedal not the actual strength of it. I have the car booked in for a service on the 20th of April, my mechanic said its not good for the clutch to be so hard and its a possible fkd cable, otherwise i may need a new clutch all together :cry:
    Any feedback / experience with that would be really awesome thanks guys.
  2. hakhawk
    moved. my ride section is NOT for posting question threads.
  3. social
    social Ute Finatic
    South Aus
    :\ sorry man, wrong vr-vs section
  4. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    possibly you broke some fingers on the pressure plate.
  5. social
    social Ute Finatic
    South Aus
    :| would i know about this? aka loud snapping noises or something? what is the extent of that type of damage...
  6. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    If you broke some fingers or some springs came out you would definitely know. Also the clutch would probably start slipping. Sounds like the cable. Was the clutch hard all the way through the travel before or stiff at the top and then softer through the bottom half? Does is engage at a different height now? You may have bent or broken the fork.
  7. social
    social Ute Finatic
    South Aus
    clutch was always hard all the way through, and it only softens a bit on the follow through wen i change gears going up not down or in first jst starting to taken off. it doesnt engage differently same as before
  8. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    It could be that the pressure plate has lost tension, that happens. It doesn't slip at all? Try moderate acceleration in 3rd and stab the clutch, does it slip then or engage firmly?
  9. social
    social Ute Finatic
    South Aus
    il give it a test when i go back out today, if the pressure plate has lost tension, is this a accident waiting to happen?
  10. ScoHar
    ScoHar Jizz in my pants
    CHCH, NZ
    VS Senator
    had this kinda feeling happen in a car of mine, im not sure about your but is it cable clutch or hydraulic, when mine went from hard to soft through the travel it ended up being the cable stretching, check if you have operation at the end of the hard part.
  11. social
    social Ute Finatic
    South Aus
    its cable and what do u mean by operation at the end hard part part?
  12. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    If the cable stretches the clutch will engage higher up in the pedal travel.
  13. social
    social Ute Finatic
    South Aus
    = bad wear on the clutch or just needa ush my foot in further?
  14. ScoHar
    CHCH, NZ
    VS Senator
    Yea thats what I mean, in other words, your clutch might be fully engaged half way down, and the soft part just being the cable stretching from being nackered
  15. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    When the clutch plate wears it will engage lower to the floor, when the cable stretches it engages higher up. When the pressure plate gives, the pedal will seem softer and it will slip under hard acceleration usually in 3rd or 4th.
    What you are saying is that the clutch operation hasn't changed, just the pedal is easier to push in....correct?
  16. social
    social Ute Finatic
    South Aus
    yea man..............
  17. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Then it sounds to me like the pressure plate has lost it's tension. If it breaks it would make a pretty loud noise as all the bits are thrown around the bell housing and cover.
  18. social
    social Ute Finatic
    South Aus
    ok well.. as i said it was softer, but not as if the lightest touch moves it, still a bit hard but yea, thanks for the info guys got a service lined up for april 20th hopefully nothing goes wrong till then
