Clutch time...
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Jesterarts, Apr 3, 2012.
  1. Jesterarts
    2010 Nissan X-Trail ST-L
    Hey,
    So it's time for me to start looking at replacing the clutch in my clubby as it's starting to slip when I get excited with the loud pedal.
    So I've been chasing around a few different places and brands.
    At the moment, I'm looking at either a McLeod RXT twin kit or a ACT twin HD clutch.
    But I have a couple questions.
    I was chatting with the McLeod supplier in Vic and he said that he doesn't think there is a need for me to replace the flywheel, just get it machined.
    Now, I'm more that happy with this since it saves me a couple hundred bucks, but I wanted to know peoples opinion on this?
    When people replace the clutch, do they usually also replace the fly or jsut get it machined?
    He also said that I shouldn't worry much about the throwout bearing, though I think I would just throw a new OEM one in since they are only $180 odd.
    Last time I had to replace a clutch is was in my old VX S and then I did the fly as well because the stock one was a duel mass pos.
    What do people think?
  2. social
    social Ute Finatic
    South Aus
    MY06 6.0L VZ Thunder(na naa na naa..)
    the dual mass in a v6 does get replaced when you do a clutch in it, but as for solid flywheels you can keep the standard and have it machined, wont create any problems keeping it. Did you talk to anyone at Australian Clutch Services? There SA based (i believe) But have a great rep on their products
  3. Jesterarts
    Cheers mate.
    Haven't talked to them but googling now. ;)
  4. some_guy
    some_guy Donating Member
    brisvagus
    VR SII Exec.
    Social is on the money - Only time you need to replace the flywheel when getting a new clutch is for Dual mass ones.
  5. Jesterarts
    This is all music to my ears... Mainly because I am a tight arse!
    Thoughts on slave/thrust bearing?
  6. some_guy
    brisvagus
    VR SII Exec.
    I heard the same thing about not replacing them.
    But if it were me id do it for peace of mind, like you said.
  7. richardpalinkas
    richardpalinkas Blown Alloytec
    Gold Coast
    Raptor Impulse VZ SV6
    What warranty on the clutch for just machining flywheel?
  8. Jesterarts
    Warrant unaffected apparently.
  9. showbags
    showbags SENIOR EL'BAGO
    VT Calais, BMW 135 m sport
    I'd replace your throw out bearing while the box is out. I've had one fail in the past after about 5000kms after replacing the clutch.
  10. DLFHUB666
    DLFHUB666 GIT 'EERRR DONE!!!
    Nhulunbuy NT
    VX SS, PX Ford Ranger XLS Dual cab
  11. Jesterarts
    Yeah, good piece of mind.
    Now a noob question. Throwout bearing is seperate to the concentric slave cylinder?
    So we're talking about just replacing the throw bearing OR the whole slave cylinder?
  12. DLFHUB666
    Nhulunbuy NT
    Im pretty sure its all one piece on the Ls1.so if you get a slave cylinder it should also have the bearing attached. Well mine did.
  13. Lumps of cheese
    Lumps of cheese welcome to the machine
    Warrnambool
    83 vh sle, 4x4 hilux, 03 monaro, 07 nightrain
    Definately do the slave, would be silly not to. Also, the bleeder mentioned a few posts up is a winner also. if you have to pull the box out, why wouldn't you do this stuff?
  14. Jesterarts
    Alright, slowly starting to put together a cost list.
    McLeod RXT twin plate clutch rated at 1000hp : $1100
    Flywheel to suit: $395
    CSC: $160 @ bursons
    Installation quote from MC Automotive in Mornington 5 hours @ $88/p so $440
    Total: $2095
  15. social
    social Ute Finatic
    South Aus
    So going with a new flywheel?
  16. Jesterarts
    yeah, mainly because no show is going to warranty the work if I don't.
  17. ashbox
    ashbox back in black
    The Car
    something black
    wow......5 hrs to fit a clutch....
  18. Lumps of cheese
    Warrnambool
    I was thinking that. We did one in a little over three hours!
  19. Jesterarts
    Every shop I have talked to has quoted 4-5 hours. Some of the manufactures have quoted as much as 6.5 hours.
  20. juiceie vh sle
    juiceie vh sle Member
    roxby downs
    VH SL/E..VF2 redline W375.. 200 series landcruiser
    put some beers on and get a mate that knows how to do it to help you its not that bad of job. i think the hardest part is getting the exhaust and tailshaft off... itll save ya $400 bucks
    might want to add a new spigot bearing and fly wheel bolts to your list as well. the bolts arent supposed to be reused
