Clutch woes..
Discussion in 'VY Holden Commodore (2002 - 2004)' started by one_and_only2004, Mar 23, 2008.
  1. one_and_only2004
    one_and_only2004 Turbo L98 FTW
    Regional NSW Australia
    Z Series Thunder Utility - Turbo
    Hi,
    my VY II S Ute has developed a creaking noise whenever i push the clutch in or out - it sounds like a big creaky spring.
    What could be causing it?
  2. one_and_only2004
    i just put a bit of silicon spray on the clutch pedal spring as one of the mechanics in town recommended that i try that. I got the brother to pump the clutch whilst i had it jacked up and it seems the sound's coming from within the gearbox - roughly around the bit that says GETRAG. does this mean the clutch is a bit #$%&ed? I had contemplated going twin plate in the future, but not after 600km's after buying it...
  3. GMMAD
    GMMAD Member
    Nowra
    3.8L GT35 4runner/VK calais
    where is it coming from the box it self or the peddle
  4. one_and_only2004
    The noise WAS coming from the front part of the gearbox where the clutch is. Took it to the dealers to fix and apparently all it needed was a bit of grease somewhere
