herb dunn
41
townsville nq
vr v8 355 manual ute
i recently had a issue with my vr v8 ute where it was holding gears too 2800rpm then banging hard shifts and having no top gear and a engine light on intermiediatly also stalling at idle i changed tps iac and still the same so i decided get throttle body off and inspect and hey presto TWISTED THROTTLE SHAFT replaced the shaft put new seals and perfect this is caused because of people over tensioning the throttle cables
Vee-ard
QuickVR95II 2010 Survivor
Bayswater, WA.
Foam Tuned VR 5.0l Ute
thanks for the info, in case anyone has the same problem.
slepar
omg duz it like...dose??
vn ss
i am having a similar problem with my auto but it only really revs out when changing from second to third was yours doing this?
