ive read on the error codes things its MAT sensor or sumthing how do i fix this? is it bad driving like this..
the mat sensor is one of the main sensors for measuring the amount of air the engine is sucking in and too work out fuel use its probably defaulted rich and will suck the gas a bit its mounted in the rear of the inlet manifold under throttlebody you should be able to see it from the drivers side theres 3 sensors there a 1 wire one for water temp guage beside that is the mat i think it has 2 wires and another water temp sensor for ecu 2 wires if water comes out you have taken out the water temp if s2 engine it will be by itself
