Code p0521
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Paul Harris, May 23, 2018.
  1. Paul Harris
    Paul Harris New Member
    Windsor
    Vz sv6
    Hi I've got a couple of codes on my 2006 svz alloytec... first of all the oil pressure sensor code and p0522 oil pressure sensor circuit low voltage.... should I just change the sensor and see how it goes or should I be worried about something else.... I took the oil cap off after I stopped the car and oil was sitting right at the top of the engine which worries me because I've never seen that before and thinking there could be a possible blockage somewhere from what I can see there's no oil leak except it looks like there's a tiny bit of a leakage coming from the tap itself which makes me think that I don't have a low oil pressure I got too much can somebody please help me on this thanks guys and girls
  2. Trev084
    Trev084 Member
    Ipswich, QLD
    VS L67 6 Seat Wagon. 2005 VZ SV6
    P0521 is a very common issue on the alloytecs, change the oil switch.
  3. gungazza
    gungazza Well-Known Member
    west suburbs
    executive vt 5.0lt VZ CREWMAN
    you will need ,a special tool ,to remove the oil pressure switch, change the switch ,and see if that fixes the oil pressure problem, how many ks, from last oil change .may have sluge build up, pull out the oil filter and have a look
  4. Paul Harris
    Windsor
    Vz sv6
    I did an oil change and a new filter about 3 weeks ago
  5. gungazza
    west suburbs
    eny sluge
