ey guys changed over my ignition leads today, but car is not starting now. Im guessing the leads are in the wrong jacks? is there a diagram of some sort to indicate which go were.. also out side of car it smells of fuel when trying to start.
It's possible that you a) knocked a wire out of the coil 2) unplugged the HES c) have it wired up all silly iv) havn't put something else back where it belongs The correct firing order is: 1-2-7-8-4-5-6-3 The top right plug on the dizzy cap should be #1, and you can work around from there. The cylinder numbers are cast into your inlet manifold behind the injectors.
yeh It seems the firing order was wrong, 3 plugs were wrong, but finally hit the jackpot lol car seems a lot more responsive now since plug change.. im a happy camper cheers guys anyway
