Coil Resistance V6
syked
Donating Member
2011 WM Caprice
Anyone know what the coil resistance should be and which pins should be used for testing the resistance?
Btw, it's a LLT Engine.
mechanic
Australia
Commodore
If there’s more than two wires in the connector, the coil will probably have a transistor on an integrated circuit between the terminal and the actual coil.
Resistance may not be able to be measured.
syked
Donating Member
2011 WM Caprice
Thanks. Yes there are 4 wires in the connector
