Coil
Justo hsv
41
Buddina
Vshsv
Hi just wondering can a coil get good spark when it's cold then lose spark when it heats up n under load as I have problems with my hsv the car will go start fine go realy good untill it warms up then the car just starts braking down sounds like its starving for fuel iv do the fuel pump ignition module plugs n leads n 02 sensor thinking it might b my coil dose any body now anythink that could help done error code check n no codes come up
Justo hsv
41
Buddina
Vshsv
Sorry it. Dose run fine on idle I can rev the **** out of it it dosnt mis a beat n when it dose start braking down I can pull over n knock it out of gear n it Will idle fine.
98NVS
Townsville, QLD
3.8L VS Commodore/Raptor supercharger
Sounds like a vacuum lines off
BlackVXGTS
Melbourne, SE
Sounds more like the Hall Effect Sensor in the distributor failing.
