coilpack is arcing
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Zuicider, Apr 2, 2007.
  1. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    any ideas? when i put up the revs the bolts that hold the series two coil back to the bracket are sparking.
  2. Bz Kn33z
    Bz Kn33z Active Member
    Mildura
    Black VN V6 Turbo
    Is it down tight? is your spark plug leads on properly? if there loose it will spark to the side of the coil pack. dont touch them when the engine still running.... i learnt the hard way :wax:
  3. immortality
    Sth Auck, NZ
    take em off and make sure the contacts are clean etc then put em back and make sure there nice a tight and try again
  4. evil_monkey
    evil_monkey New Member
    Australia
    Holden
    remove the motor and put in a 5.0L that should fix it mate ;)
  5. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    are u gonna fund that sean?
  6. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    sure you could borrow his motor;)
  7. Zuicider
    Zuicider Banned
    Stonedville
    Set of thongs
    or flog but its making a rattle so i will prefer the stripped vr block in the carport, leats i know whats wrong with it
