H
holdenlove
Guest
cold air intake(instructions)
recently instald my own cold air out of pvc pipe. noticed a little difference. found out that the origanal one should be blocked of because it still sucks in warm air.
1 piece of 90mm pvc 0.5m
1 90 degree angle 90mm
1 45 degree angle 90mm
some silicone and your away.
take off your air box youl need a special tork key. cheap about $5
cut a 90mm hole(circular) scetch the pvc pipe and outline it on your air bok.
put 90 degree angle on the straight pvc pipe and slot in then put your 45 degree one at the bottom. now everythings inlinie use some silicone to seel up and away you go:driving:
