Cold Air Intake, is it viable to make your own?
Himynameisari
Queensland
2011 VE SV6
Im no mechanic, but looking at some of the off the shelf products already available, they seem to be just a few pieces of pipe and a pod filter on the end.
These usually go for $250+ which isn't out of the budget, but it's also at that limit where I think to myself "Well I could build one for a quarter of the cost!".
Has anyone made their own? Is it worth making your own? What issues could I run into?
Bubbs64
2014 SSV VF Redline Wagon
Hi there,
Just had my VF Redline fitted with an OTR system which isn't hard to do BUT to get the best outcome you'll need to have the car re-tuned to get the best results.
vongy10
Gunnedah
CV8 Monaro V2
Hi there,
Didn't even answer his question...
Op, a simple intake can be done cheap and easily. Just need the right sized pipe, an elbow bend or two, some couplers and a filter. You could make one using plumbing pipes if you felt like it, seen it done before.
Bubbs64
Sure it can be done but what's the point in putting in plumbing pipes if there's no improvement in performance !
vongy10
Gunnedah
CV8 Monaro V2
What makes you say that? It'll still be better than the stock system.
commodore665
expat Saffa
54
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
No , you'd be better off buying one from a reputable manufacturer .
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
The 'reputable manufacturers' started out using paint trays from Bunnings...
Freedon
queensland
vu ss
i just got a airhammer cai kit for my ve, cost alot less than $250
SnowDoggyDogg
2ltr? = Only milk & juice
Goldie
Gen F GTS
It could be viable to make your own toilet paper... but(t) I'd leave that to the pros too.
There are enough secondhand kits floating around that you should be able to score on the cheap.
Hell check the wreckers too, I'm sure people who performance mod their cars right them off too.
