Collant and oil filter
robert43
62
Bog standard vz executive
Hi I own a VZ v6 exective and was wondering when I read in the owners hand book it states its the same as the 5.7 v8 is this what any of you v6 use? .Also I was wondering if the oilfilter is the same ? thanks ( as I dont like the fact that it is 1 year between oil changes as we only do 16k a year :whistling
Ralph1
56
2005 VZ SSZ
Even if you only do 16k a year you still should drop your oil and replace your filter at least every 6 months. Even if you do it yourself and get holden to do it again during the once a year service. This keeps your oil and engine happy. I had a Uh Hum a Ford :whistling that only did 3.5k a year but I still did the oil and filter every 6 months.
robert43
62
Thats what I am bascially going to do
I will have to go to Holden to get a filter thanks
Aggro_VE
The Overseer
Lake Macquarie
A lazy VE
Changing your oil filter is relatively easy, the torque settings for the bolt is 8Nm if I recall, ask Holden I'm sure its 8Nm, finger tight then a quick nip up. That's one bolt you don't want to strip or worse still crack the housing.
Sulli
VZ Crewman
Where exactly is the oil filter, might sound like a silly question but i will be honest i have no idea where to find it.
sulli
IPCOlsenVZ
05 VZ Commodore Equipe
Oil filter location
With the top taken off.
Filter
Torque settings
Filter: 25Nm
Drain Plug: 25Nm
danja
Swerves for gay koalas
CBF 250 and a Levin ZR
Isn't the Alloytec oil filter a cartridge on the top of the engine? My mate has one and says it's the easiest oil change he's ever done in his life.
EDIT: ^^^ Yes it is :)
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
WHAT A GREAT IDEA!!:thumbsup:
Verds
VZ Crewman S
That so beats getting under the car with the filter spanner and wrenching away on your back just to get covered in oil (if your too slow and a first timer lol)
Viagra
VZ Adventra
Sump Plug location?
Thanks for the awesome picture..
Any chance of a picture of the Sump Drain plug location?
Need to change the VZ Adventra engine oil, and is it the 13mm plug directly below the front-right driveshaft? or maybe thats the front transfer case drain?
Thanks in advance..
