Commodore misfire
Hayden sanders
Taree Nsw 2430
Vs commodore vacationer 3.8L v6
Hey guys, have had a misfire in my 95’ vs commodore I have replaced the plugs, leads and coil packs along with the card underneath the coil packs. Still have a miss, holds shitty idle and when I give it abit is just misfires even more, could it be a possible cat failure and if so how do I test it? Only got common hand tools
kangaaa
2002 VU SS Ute.....2007 VE SS Sedan
could be your O2 Sensors...
worth a try
Fu Manchu
WA.
Missfires can be O2 related. Also blocked or underperforming cats. Underperforming PCV system. MAP sensor ok? TPS?
Immortality
Staff member
Sth Auck, NZ
Have moved thread to the appropriate area.
Have you checked fuel pressure/flow? Lack of fuel will cause symptoms like you describe.
Trevor loves holden.
vs commodore
Maybe its your wiring harness to the DFI, best to hook up your car to a scan system to pin point the issue. This will tell you if its O2 sensor or spark issue, good luck.
shane_3800
35
places
vr commo
Lol could be your engine. No but seriously as you've seen it can be a number of things how prepaird are you to diagnose this? Do you have the diagnosis equipment? I just had one come into work with a miss and I'm trying to find a way to palm it off to a workmate as it could be a one hour fix or a two day fu.ck around.
Fuel will show up accross all 6 cyl a cat will be 3 same with O2. My guess is it will still be spark or a dead injector.
shane_3800
35
places
vr commo
Sorry I realised just now it's the older style six lol sorry. It will likely be an injector repco/bursons sell exchange sets.
Utel67
Tasmania
Vs s3 ute
Check to see if you have any fault codes possible faulty TPS
