Commodore Omega VE ABS Fault
LenaP
61
Bankstown
Commodore VE Omega
Car won’t start - ABS light flashing - what does that mean ?
Dr_Mutley
South Adelaide
VE Calais
Mine was a blown fuseable link at the battery - no crank
check both on the terminal then move down the line
LenaP
61
Bankstown
Commodore VE Omega
Thx for ur reply - much appreciated
I ended up getting a jump start n everything was fine. Car was due for service so took it to my mechanic the next day n he couldn’t find a prob - I must’ve left something on n it killed the battery.
LenaP
61
Bankstown
Commodore VE Omega
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
VE's are power hungry, if you battery is low its one of the first faults that flash up when trying to start, if you travel far enough each drive battery should recharge, you should get battery load tested and how old is it
