Commodore problem
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by bowmatty, Mar 1, 2014.
  1. Bowen
    Bowen New Member
    Alstonville
    2002 VX S manual 3.8L SP
    I would never use any type of stop leak additive on anything unless I was replacing the entire cooling system afterwards ie water pump , lines, heater core, radiator, and hot tank the engine lol that stuff is nasty! Iv seen it completely block a thermostat and cook a set of heads but in saying that u do have a valid point it is a very cheap option by comparison and if I wasn't capable of changing the valley gasket and didn't have the $600 to pay someone I would probably do it too :p lol hope u fixed your car dude let us know how you went
  2. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
  3. hotrod
    hotrod Banned
    victoria
    commodore s2
    yea 75 for the plastic ones , get the foil ones last a life time , I see ya can get a pair for 110 + postage on ebay.
  4. hotrod
    hotrod Banned
    victoria
    commodore s2
    if that's the case why doesn't it have those warnings on the bottle , and you think the company be sued over it if it was to cause damage to ya cooling system .
  5. hotrod
    hotrod Banned
    victoria
    commodore s2
    also was it rislone brand that caused the problem with the blocked thermostat , if ya go to there website and look up frequent asked questions on the copper liquid you will see there products does no harm , it even tells you on there site how it works . And you say it cooked a set of heads , wouldn't you see on the temp gauge that its running hot , and pull over. so don't make assumptions on products used as rislone brand is safe. don't use any other brand than rislone!!!
  6. Bowen
    Bowen New Member
    Alstonville
    Hey if it was me yeah I would've pulled over ay haha i always periodically glance at the temp gauge, but this was a mate who doesn't know much about cars, he also found out the hard way that tectaloy make absolutely **** coolant, better off putting water lol
  7. WhiteOx
    WhiteOx Member
    96 VS II Acclaim
    The stop leak additives can work if used correctly.
    The problem with blocked cooling systems is because people leave the stuff in there when you're supposed to flush it out after a couple of days.
  8. bowmatty
    bowmatty New Member
    3.8 V6 Vr commodore
    Bought a manifold gasket kit HA416EZ today from supercheap $42 !!
    Will take a look tomorrow. :)
  9. bowmatty
    bowmatty New Member
    3.8 V6 Vr commodore
    Which gasket set do i need? ....EZYFIT Manifold Gasket Set HA5001EZ or EZYFIT Manifold Gasket Set HA416EZ??
    I have seen there are two sets ummmmmmmm
  10. Jxfwsf
    Aus
    commodore
    HA416EZ is for the buick 3800 VN-VR engine (correct for your engine)
    HA5001EZ is for the ecotec vs/vt etc etc, won't fit the earlier ones.
  11. bowmatty
    bowmatty New Member
    3.8 V6 Vr commodore
    Cheers pal
  12. bowmatty
    bowmatty New Member
    3.8 V6 Vr commodore
    Right im intending to fix the intake manifold this weekend!!
    I need to get a torque wrench but i dont wanna buy 1 just for a days usage!! can i hire one??
  13. Wombles
    Wombles Cars cost too much.
    They become very handy. For 100 bucks for a 1/2" drive torque wrench.. may as well buy.
  14. kiwicon
    kiwicon Active Member
    NZ
    VS V8 Manual
    Just buy a few of cheap Chinese 1/4" ratchets and keep tightening until the ratchet head snaps.. should be able to grab half a dozen from the local $2 shop
  15. bowmatty
    bowmatty New Member
    3.8 V6 Vr commodore
    Can you hire? as i haven't really got $100 to buy a torque wrench which i will hardly use.
  16. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    Kenards hire use to,but its been yonks since Ive been in a store :)
    also think coateshire do as well coateshire.com.au
