Cars are pretty disposable these days unfortunately. That one surprises me about the honda though! They're generally pretty well engineered!
can I ask you try an oil change on a 2005 CRV? ( I did one on my daughters)
yerp the sump plug is a doddle, exposed and where you expect it
the filter?
hmmm... that is another story
firstly you need the VERY exxie Honda factory tool ( especially if genuine filter)
secondly you dislocate your elbow and wrist so that you can reach up
and put the tool on the filter and with the extension start removing it
or take a 400mm long screwdriver and hammer the pharker thru
the oil filter, move it 10mm to the right, grab hammer and do that
routine again .. until filter falls onto drive shaft (whereby you slide it to
the end and it falls on the ground)
why is it so hard? Honda engineers thought it would be fun to
put the oil filter right under the inlet manifold and also on top of
the cross drive shaft for the FWD with a gap of maybe 50mm
to reach thru to access it
