NickHidro
- Nov 1, 2016
- 42
- 5
- 8
- Location
- A.C.T
- VT Executive S1
Hi guys
I'm on my fourth alternator for my 98 VT ecotec in a year and it's failing on me again. They've all had issues with charging at too low a voltage (11.9V idle and around 12.9V at 2000rpm, then after a month or two even under load it is about 11.9V). So far I've all but the original have been bought from wreckers (with the second one being DOA so I don't really count that one) so it's perfectly possible that they've all just been broken but I find it strange that something that's usually as robust as an alternator is dying so often.
Do you guys think it could be something esle potentially damaging the voltage regulator everytime I swap it over? Has anyone had any similar experiences to this?
I should also note that after the second one died, I changed the pathetically small charge cable for a beefy 4 gauge one going straight from the alternator to the battery so I don't think it's the usual charge cable overheating issue. Also I have an aftermarket stereo installed but I'm not sure of the power draw it requires as it was from the previous owner.
Cheers for any help guys, it's greatly appreciated.
